55 Chevy Dirt Slinger
Started by thirdgearspeedshop, January 21, 2019, 10:28:06 AM
 :)  TGSS,  This is my opportunity to offer my standard joke when anyone comments that a model is looking good " so far. "  Most of us longtime guys around here get a laugh out of it.  But that's all it is ----  just a joke.
Your Chevy is looking good, and I am sure it will be great when you finish it.  Hope the rest of it goes easy for you.
Quote from: john2 on January 30, 2019, 06:17:49 AM
;D ;D Yes, let's hope I don't screw it up!
This turning out real nice!
Small update:
I've got the dash mounted, pedals and steering column in. I sourced a steering box from a 66 Nova, and began fabbing the roll cage. Front and rear hoops are installed. The seat is temporarily placed for now. It's a resin piece from Sheldon Rothwell at the Outlaw Speed Shop. More to come
UPDATE:
I built the front hoop and tied it into the roll cage through the holes in the dash, built a structure for the radiator to mount to and used angle stock on the radiator for mounting, made a lower radiator hose out of round stock, and drilled holes in the front of the hood.
Question for those of you who know these cars well:
Did the hobby stock divisions back in the day use stock or heavy duty shocks up front? One on each side? two? Photos of a typical set up would be great.
Thanks
Man Third gear...this is really looking good. The shock question is a good one. I think it depends on what racing Assc. your running with. The west coast folks might let them run beef'd up shocks while the east coast folks might make them run stock shocks. Thta's what I remember anyway.
Third, since you have gone with the wide five hubs and wheels, I would add an out board racing shock on the front.  Where I am, cars like yours would have been in the "Late Model" class until about 1971 and then it would become a Hobby Stocker all of which used racing shocks here.  The most common spot to mount the front shock was the lower A arm close to the ball joint and top mounted to the front engine cage hoop.  The rear would be the builders choice.  Here is a typical example for a tri-five chassis.  You can see the top of the shock mounted to the front cage, the lower end to the front side of the A arm hidden by the tire.  I have seen all kinds of odd ball set ups but the fast guys were like this.
I agree with Leftturns. Around Iowa, the couple year old late models generally became sportsman cars. A little heavy for evolving late model classes and not quite enough motor either. They would have the old late model running gear and suspension parts.
Great pictorial build! These how to's are informative and inspiring. They make this forum the place to be for short track subjects! Thank you for taking the time to document it.
Tb
Ps...PM sent
My car had one stock shock on each corner-now remember this was back in the 60's in SE Wisconsin and also the only rim that could be off set was the right front as that one took the most stress.  Hope this helps.
Quote from: Fordguy01 on February 23, 2019, 01:12:20 PM
I too raced in SE Wis. Sportsman at Hales, Cedarburg, and Slinger. Two heavy duty shocks on the right front, also pie cut upper control arm to help lead it into the corner. I burned a couple of big Merc spindles until I put a Stock Car Products hub on that I got from Jimmy Lord. Never had a problem after that. BTW, I was running '62 and '64 Ford Galaxie.
Thanks for the feedback guys. It's great to hear from the guys that actually raced and built these things back in the day. Much appreciated.
Just got around to seeing this....a GREAT tutorial & subject matter! Looking forward to the completed project!
UPDATE:
I got the front bumper and nerf bar installed. Still on the fence about attaching the stock bumper or run it as is. The roll cage is almost complete. It fits really well within the body and matches the shape of the body real well, I'm happy with it.  Rear firewall has been shaped and installed and the gas tank has been installed. Just a little more frame work and I can move on to the engine and smaller details before paint. It's getting there.
