Late Model Camaro
Started by thirdgearspeedshop, April 19, 2019, 11:43:33 AM
More progress was made over the holiday weekend. I sorted out the steering shaft, installed the master cylinders, finished the tin work and started on the drivers side door bars. I also got it up on 4 wheels and test fit the body. Still a ways to go but it's coming together.
That's sure looking good TG. Your fab work really shines.
Your work is really very  good, and certainly far beyond me.  It's going to be quite a model when you finish.
As I sat here looking at the pictures from early in this topic, I couldn't help but think how much more interesting these cars were than those of today.  You know,  the square , flat ones,  that look like they are going to fall over in the turns.  I guess that is the artist in me poking through.
RandB11
Incredible fab work! Been following this build, can't wait to see more!  It really looks good with the body on it. Gonna be a good one!
Rick  :)
I finally got some paint on this one. I have finished the rear end and seat. Also finished the front suspension and plumbed the brake lines both front and rear. Next will be rear shocks, fuel cell and engine detailing.
Hey third that fab work is beyond outstanding can't wait to see the finished product.  And for the header you tube, put me down for 800 yesses and thanks for posting this build!
WOW! This is one outstanding piece of work!!  I know how many hours go into my builds... this would take me several years to accomplish something with this detail!
Alright then...TG..your work is really shining on this bad boy. You have the attention to detail in Spades on this build.
Quote from: Gary Davis on June 12, 2020, 03:36:08 PM
Thanks Gary. I wasn't sure if the brake line to the rear would have run under the frame like that but that's about the only way I could get it to work. I'm also missing a couple support bars in the rear ( mental note for the next one) hopefully it won't be noticed.
Super detailing. Wish I could get my cages and other bars to look so good. Do you pin them? I haven't figured out exactly how to do that yet!
Quote from: Dirtman on June 13, 2020, 07:46:29 AM
Thanks Rett. I do not pin the cage bars. I fishmouth them and use Tamiya styrene cement. The solvent based cement welds(melts) the sytrene so sometimes a fishmouth is not needed. I did pin the leaf springs in place, mainly for mock ups but the pins allow for assembly without glue also.
Quote from: thirdgearspeedshop on June 13, 2020, 08:45:26 AM
Thanks Mark, I'll have to look for Tamiya Styrene Cement.ds
  Everything is looking absolutely great.
  I had the same issue's with the rear brake lines on deciding which way to go when I started plumbing brake lines.  I figured that once everything is in place, things like brake lines, fuel lines, etc., that those lines somewhat disappear, so what I do is just run them along the top of the rear frame and/or some of the horizontal bars of the cage to where the rear fire wall is to give the appearance that they pass thru the interior cockpit. Take a look at the on going '78 Mustang II dirt late model build (page 3) and you will see what I am talking about.
I've got the engine and fuel cell almost ready to drop in. still need a black wash on the valve cover breathers. Fuel lines are in place, plug wires and magneto are installed. The air cleaner and fan will be put on once the engine is in the frame.
The carb, valve covers, valve breathers and oil pan came from Ron Coon. The magneto came from Morgan Automotive Detail. Headers, fuel log and fan belts/pulleys are scratch built. Block, heads, intake and tranny are NASCAR AMT.
ModelCarMan AKA Ricky
