Short Track Models
The Bullring!!
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Gallery
Login
Register
Short Track Models
Construction Topics
Tips-tricks
56 Ford
« previous
next »
Print
Pages: [
1
Author
Topic: 56 Ford (Read 1330 times)
Hero Member
56 Ford
on:
July 08, 2020, 09:38:32 AM »
Anyone have an idea how to lower the front suspension on a '56 Ford? Spindle has two holes, using the top one just doesn't do it. This is a mild '50's custom I'm working on. I just know some racer will figure it out.
Logged
Hero Member
Banned for the greater good
Re: 56 Ford
Reply #1 on:
July 08, 2020, 09:55:54 PM »
I'm guessing your working with the AMT/ERTL '56 Ford Victoria kit....
there's a couple of possibilities....
1) put the round peg on the brake drum in the top hole (raised position) and rotate it so that indent portion is pointing up.....keep in mind you will have attach the pin that goes through the spindle to the brake drum and then remove enough of the pin so that it is flush with the back side of the brake drum.
2) remove the locating peg and simply attach the brake drum to the spindle at the desired height.....you will still have to remove enough of the pin so that it is flush with the brake drum.
Logged
Hero Member
Re: 56 Ford
Reply #2 on:
July 09, 2020, 07:25:11 AM »
Thanks Brian, I'll see what I can do with that! Appreciate the help.
Logged
Print
Pages: [
1
« previous
next »
Short Track Models
Construction Topics
Tips-tricks
56 Ford
