Quote from: TarheelRick on January 14, 2025, 04:31:06 PMThere is a light in the tunnel and I don't think it's a train. Making great progress. Keep those updates coming.
Thanks, Rick. Will do.
I was going to start repainting the body, but I got to looking at it and realized I had removed the door handles which the real car had an had done the park lights wrong. So, I started to fix those before I can repaint the body.
Mark, i know i am late with this response but what did you decide to do with the chrom painted pieces?
I do empathize with you on the painting/handling process with it, i put together a 1974 Roadrunner and used it on the wheels and bumpers. They started out with the reflective mirror shine to them and by the time i had them mounted on the car/in the tires, the finish was horrible. Pretty bad results for something that is as expensive as it is...
Quote from: 18degrees on January 15, 2025, 11:21:56 PMMark, i know i am late with this response but what did you decide to do with the chrom painted pieces?
Thanks for your question, Dave. It's good to know I wasn't the only one who has had this problem with Revell chrome. I went ahead and put future on the wheels which did not hurt the chrome appearance on them, and I will try to redo the air cleaner with Revell chrome and then future it before I start handling it again. Revell should put on the can you might want to clear whatever you're doing with this product before you handle the parts you paint with it.
Got some stuff from micro-mark. Thought I would get a real cutting pad to work on and some other stuff I can't get locally.
I had to make the park lights a little less wide. They needed to be 5/16 of an inch to be the proper scale size. Also finished the left door handle. Now I just need to add a raised border around the park lamp openings before I can begin the final sanding before priming the whole body again so I can repaint the body.
I needed to round up the corners of the park light openings before I make a filler for them.
Finally got the park lamp opening inserts finished. Will paint them black and install them after the body is painted just like the door handles. Should help to make a cleaner looking build which I fall down doing a lot.
Mark
Not to hijack your thread but i am using the chrom on some Indy Car wheels, gonna lay down some lacquer clear spray on them. Will report back how it does.
Quote from: 18degrees on January 22, 2025, 10:02:29 PMMark
Thanks, Dave. Feel free to post them here so I can see your results of the clear lacquer over the Revell Chrome. The stuff really works well after just putting it on its just the handling it can't take.
Got the body sanded and ready for the Mr. Surfacer 1000. Suppose to get back in the 60's on Friday. Will also rechrome the air cleaner at that time. Never thought I'd see my little truck covered in this much snow
The truck does not look happy with you. On the other hand... the build looks very happy. Coming along nicely.
Quote from: MarkJ on January 23, 2025, 07:16:28 AM
Mark (and anyone else interested in the subject), i went ahead and started a thread about the Chrom in the Bench Racing section, didn't want to completely hijack your thread and send it in another direction.
Quote from: 18degrees on January 23, 2025, 03:42:00 PM
Thanks , Dave. I will surely give it a look. Do you have a link you can post here for easy transfer over to it?
