1972 Bobby Allison Monte Carlo
Started by MarkJ, April 23, 2025, 11:43:05 AM
0 Members and 6 Guests are viewing this topic.
Quote from: MarkJ on May 15, 2025, 07:47:42 AM
Quote from: 18degrees on May 14, 2025, 05:49:15 PM
Quote from: MarkJ on May 14, 2025, 03:59:16 PMDave, I can't remember when I bought this kit, but it was at hobby lobby and wasn't that much. I might have paid 40% off for it as well. Your kit might not be the model king kit like this one and is probably better engineered than this one. These model kings are always a little weird.
yah, your build made me go back and look at mine... AMT reissue from a few years ago.  and surprisingly it's closer to being done than not, so that may be the next one to roll with.  no idea why i abandoned it, doesn't look like i had problems with it that stumped me... may have been what i was working on when i moved.  i distinctly remember working on this at my old house.
Just remember, the wheels that come in the model king kit are way too deep set to be like the ones on the actual car. I had to get some PPP wheels and tires to fix that problem.
Not gonna be a problem since it's the AMT version. Also, ahead of you on this part, PPP wheels and tires already painted and decaled.
Quote from: 18degrees on May 15, 2025, 10:38:57 PM
Thats good. Really looking forward to seeing your build. I'm sure I can pick up some pointers from it to keep from making a major mistake.
The fairing definitely looks aluminum and stops right at the roll cage upright at the drivers window. It looks like his seat might be red unless hes leaning way forward in that shot.
Finally got the front of the build finished and ready for primer and paint. I want to get the black things ready to paint first so I can do the red and the black items in one paint session, I will paint the gold parts last because masking even with the aluminum foil messes up metallic paint. The red parts will be okay to mask so gold will be shot last.
Mark,
Thanks for the tip on masking metallics. I got mine out, painted the interior of the body and primered the outside. I was debating which section would be easier to mask off and was going to paint the gold first then the red. Now i will do the opposite.
Some more. The little square deal is the head restraint in its formative state. Needs some filling and sanding before glueing to the cage.
Hey Mark, looking good so far.
I am finished with the decals on my build, have a TON of extras leftover from the Powerslide sheet plus the kit sheet. If you have any decal issues lemme know.
Quote from: 18degrees on May 30, 2025, 06:43:33 PMHey Mark, looking good so far.
Thanks, Dave. I might just have to take you up on that if I mess a decal up. I don't think that sheet is available anymore if I needed to buy one. Hopefully I can get them on with no problem.
Got some more work done here and there. Added some material to the treble bars in the left door that I will have to putty and sand. Also added some crush panels around the rear fender opening so you can't see the rear tires from inside the vehicle. Also, redid the fairings around the quarter glass openings. I can still get the left roof bar on the cage closer to the roof to shore up that gap some more.
Quote from: MarkJ on May 31, 2025, 05:36:19 PM
Just looked on Mike's site and there are 3+ in his inventory, so they are available. But the ones i have are cheaper ;D
Thanks again, Dave. Thats good to know that Mike has some, but I will check with you if I just need one decal and you can part with it.
