Author Topic: Dry sump oil line HELP needed  (Read 8702 times)
« on: July 05, 2018, 06:57:03 PM »
  Building my first dry sump engine....what is everyone using for the stainless steel braided oil lines ...pan to pumps, pumps to reservoir, etc. etc.  looking for something around 1mm (+-)
« Last Edit: July 05, 2018, 07:30:08 PM by Brian Conn »
Re: Dry sump oil line HELP needed
« Reply #1 on: July 05, 2018, 08:16:03 PM »
Detail Master.  Go to the site and they have all the A/N fittings, Braided line sizes including a chart for sizes.
« Reply #2 on: July 05, 2018, 10:37:43 PM »
OH YEA...forgot about them....
Any ideas on an oil tank reservoir?   Teds Modeling Market Place shows only an Aluminum tank which he is out of.....anyone else carry one?  It can be a resin cast
« Reply #3 on: July 05, 2018, 11:57:59 PM »
Jack one out of an early Monogram Ford or GM Nascar kit.
« Reply #4 on: July 06, 2018, 05:49:12 PM »
  I see your Jack and raise you a pair of Deuces  8)......
       Don't know which kit this comes from...got it out of the salvage bin at the LHS...its the on piece combo dry sump pan, starter and 3 stage pump.  I need to move the 3 stage pump to the Right side due to clearance issues with the fuel pump and area where the oil line fitting screws onto the original oil filter fitting...another piece that I will make a mold of and resin cast.
  I'm trying to get my building Mojo back with that Mustang II dirt Late Model that I was working on.  :-\
« Last Edit: April 14, 2022, 04:50:49 PM by Brian Conn »
