Kasey Kahne 2004 Dodge #9
Started by 18degrees, March 08, 2025, 09:05:39 PM
to finish this build, i literally have to apply 5 decals.  and attach front shocks, air cleaner, interior vent hoses, radiator, the window assembly and the adjustment tubes that go along with it.
but i decided to show the last little bit...
here is my sophisticated chassis assembly jig ;D
and the mostly decaled body
please ignore my feet in the last pic  ::)
i had to go with the 2005 Charger trunk lid decal, the appropriate 2004 Winscals one broke apart pretty bad when i tried to use it. glad i didn't use those decals, every one that i have tried to use has broken apart.  can't imagine that the side decals (Ram's head and stripes) would have fared any better.  the only (barely) usable one is the "DODGE" above the grilles.
some better interior shots of Jaye's dash
i also did a test fit of the body with the cage in place, just to make sure nothing rubbed... evidently after i glued the cage to the chassis something flexed a bit, the right front is slightly off the ground now >:(
too late to fix that now...
Dave, the dash looks really good with the extra detail.
