Logan Schuchart #1s Drydene sprint car
Started by 18degrees, October 14, 2025, 04:44:59 PM
cut some carbon fiber decals for the inside of on of the body panels, will see how that works out...
and i am thinking that i will glue those fabbed body panels in place so i can get the front suspension attached.  everything but the nerf bars are painted and either waiting to be decaled or glued in place.  the nerfs are going to be a different story, i have made these before but for this one it looks that the headers are going to cover the area where the part i have to add would attach to the chassis.
again, as i said previously, i will figure it out, i always seem to be able to.  just that a lot of other things need to be decaled and in place before i can work on them.
little bit more done, a bit of a mock up.  front and rear suspensions are done.  in the office photo you can see some of the carbon fiber decals.  decal work on the hood and main body panels is delayed due to the carbon fiber factor.
Carbon fiber decals are done on the hood and one of the body panels. This is a real PitA, not able to cover everything due to angles and nooks and crannies and such but the outcome should be fine for a shelf build. Not gonna enter this into any contests. Didn't do all of the hood, just the visible parts, and the second body panel is coming out a little better i think. Applying the carbon fiber decals in smaller sections, the good thing is the decals blend together when they overlap. Lots of shape tracing, cutting and then more trimming, plus lots of decal set and massaging with a brush. Keeping my fingers crossed that when i apply decals to the outside of the body panels i don't damage the carbon fiber ones by handling them too much.
Pics will be taken and posted once the last section is done.
almost got the body panels carbon fibered, the decal sheet is from Slixx.  they don't contour to the shapes and curves very well so there is a lot of decal set.  they tend to chip a lil bit when handled so i am going to have to be pretty careful when i apply the decals to the outside of the panels.  hopefully the gaps aren't too noticeable when they are in place on the chassis.  thought about using a sharpie to fill the gaps.  also got one side of the hood done.  had to add some tube to the axle ends to space them out, the SWS wheels sit too far in for my taste, they are very close to rubbing the rear torsion bars. i anticipate that the right side headers are gonna be a tough fit with that extra lower panel in place.
Really coming along nice.Can not wait to see it done.
not much progress on this, it stalled out... just kinda lost interest in it. not sure why... it will get done, it's still in my work area, but i started on a different, somewhat obscure, one-off race build.  and that's been moving slow, too, since i haven't ever built one of these kits (ASA Thunderbird) and have to actually read and follow the instructions.
and Steve, i changed my signature pic... hope you approve of this one ;)
i just wish that imgur still gave the option to size the pics, from what i can tell/find the message board format only has one size.  someone please correct me with instructions/steps if i'm wrong.  not fond of my signature pic being so big.
I love it Dave! Make those kids earn it. 😂 My two sons and I used to go to the go kart rental track and have at it. Probably shouldn't be one of my proudest moments, but we all got tossed out one time for roughing each other up. That was back when I had my 1:1 race cars. Good times!
so i got the carbon fiber decals applied and am about to start work on the last few decals for the outside of the body panels.
if you want to know why this has taken so long, take a look at my most recent Davey Allison build in the NASCAR showroom.
Some great looking work going into this build. Keep at it. Looks like it's going to be a beautiful build.
ok, so i managed to find an extra left side body panel in my parts.  went ahead and cut it up and added a flat section of sheet, just have to clean it up and fill the gaps.  if this works it will be both good and unfortunate, good in that it will make the decal lay like it should; unfortunate in that i will have to repaint and re-apply the carbon fiber decals.  and i don't have an extra right side panel so i will have to work with the one that is done, all but decaling.
sometimes i feel that it is easier to show a pic and explain what i am after versus just explaining..
the panel on the left is the modified one, the one on the right is the finished (all but decals) one, and below is the decal that goes on it.  so you can see that it would NEVER work with the kit panel out of the box. once i get around to cleaning it up i will report back...
Got the left side panel puttied and sanded and is being primed.
Since i didn't have a spare right side panel i had to hack up the one that was already painted and carbon fibered. Man, it broke my heart to pull all them CF decals off... it's being puttied at the moment.
got 'em cut up, patched, puttied, sanded, primered and painted.  original kit piece on the bottom
