Here's how I paint wheels of the type shown here.
I found that weather you spray paint, or use a brush, the paint don't want to cover properly in the cracks and crevices.
Resin wheels from Big Donkey.
1. I clean with alcohol using an old tooth brush.
2.
I apply a coat of Future on the wheels prior to painting. This seems to help the issue.3. Painted these with a couple coats of Krylon white primer.
4. Then Painted with Krylon white satin.
5. Painted the red outer edges using enamel paint using a toothpick. Then painted center red with a small brush.
6. Painted lug nuts and axle bolts with silver using a toothpick.
After white primer.Hosted on Fotki
After white satin paint.Hosted on FotkiAfter red and silver paint.
Hosted on FotkiIt would be interesting to share how you guys paint these wheels. You probable have some better methods than I have.Bob
