Early 70’s Late Model Resin Body
Started by spotter23, February 25, 2019, 10:00:00 PM
spotter23
Looking for suggestions for a resin or kit early 70's Camaro for a asphalt late model build.
Thanks
MG
  I take it your looking for something between 1970 and 1974?   The only other thing that comes to mind is the AMT Baldwin Motion 70 1/2 Camaro kit.
spotter23
something similar to this is what I would like to build
https://www.google.com/search?q=david+pearson+late+model+camaro&tbm=isch&source=univ&sa=X&ved=2ahUKEwj_nL-cv9ngAhXJV98KHexKClIQsAR6BAgGEAE&biw=1600&bih=754#imgrc=rfsqoOReoEPCRM:&spf=1551187237879
I've seen photos of builds close to this and assume they are resin bodies or a kit body with a resin front nose. I looked at Big Donkey but didn't see exactly what I was looking for.
Thanks
MG
...That David Pearson ride would pretty much be any Camaro from 1975 thru 1981
RCR
Also check Ron Coon Resins. We carry 5 different vacuform Camaro bodies. Here is a customer build that one of our bodies was used as well as tires, hubs, and wheels. Click on picture to enlarge.
#5
Hi Ron!!!  Are you going to be at the Nebraska Challenge on March 31st???  I would like to go but I'm not sure whether it's going to work out just yet!!!
RCR
I won't be there as a vendor. I usually don't attend very many shows due to the fact that I do the majority of my binge pouring on the weekends. I do however live fairly close to there if you'd like to stop by and say hi...the beer is always cold  ;D
I still don't know for sure if it's going to happen but I'll see.  If I do get to make the trip I'll give you a shout!!!
